mfarrukh :
It may or it may not
If you have put the new Radeon 5xxx series card in your PC you are buying a overpowered PSU, perhaps a 600W will be more than fine for even 2x5770
If you have 58xx or 5970 in your PC, then yes you will probably wanna go for +700W PSU, as you are planning future upgrades.
GooD LucK
this is going to be my build. will i be able to upgrade with this mother board? i am a beginner, never done this before , ive always had a Dell. Also im not sure on a Video card, can you help? Dont wanna spend over 300.00 and i want something that will be good for 2-3 years?
case: Cooler Master Storm Scout
board: ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard or ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Processor: Intel Core i7-920 Bloomfield 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor
CPU Cooler: COOLER MASTER Intel Core i7 compatible V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler
Memory: OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK
Power: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC or the 850
Video Card: SAPPHIRE 100286L Radeon HD 4860 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Hard Drive: SAMSUNG EcoGreen F2 HD154UI 1.5TB 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Dvd Drive : SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 22X DVD±R DVD Burner
