Hi Guys -
I'm hoping you all could help with some fan recommendations. This isn't an overclock, it's actually a hack done to a server.
I need the following:
PWM fan (needs to be controlled, and report to firmware)
High RPM capacity 4000rpm+ (read below for why this is necessary)
Relatively quiet at speeds of around 1500-2000RPM
Here is the deal:
The problem here is that the server's firmware simply sets its fans to spin at about 30-50% their capacity under normal conditions. The server originally had 6x 6000rpm 92mm fans that usually spun between 2200-2800 RPM. Even at these speeds this thing sounded like a helicopter.
I had replaced the fans with some Scythe Kama fans that had a maximums RPM of around 2500 and rated for good airflow. Putting in the lower rpm fans helped with noise tremendously, however the fans are now only spinning at around 600-800RPM and are having a hard time keeping some components cool (although the overall case temp is good).
I want to replace these again (or at least a couple of them) with some fans that have a high RPM rating. The RPM rating HAS to be high, since the firmware will spin them at a percentage of the rating. Therefore the standard "quiet" fans that only spin at like 2500 or below aren't good enough.
thanks!
Here is the deal:
thanks!
