Yes No
Ads
Dell Power Supply Options
Forum CPU & Components : Power Supplies, Cases & Mods Dell Power Supply Options
I recently got a free graphics card that requires a 500W or greater power supply, but my Dell Precision 390 Workstation only has the retail one, which provides up to 375. I'm probably going to end up buying a new power supply to fit this card, and I need some help being pointed in the right direction. I've also heard that computers like mine require a Dell power supply due to limited compatibility. So, I just need a power supply that is:
Compatible with a Dell Precision 390 Workstation
Able to provide at least 500W
Relatively Cheap
The cost isn't a huge deal, but I would prefer it to be under $100. Thanks in advance!
Reply to doxq
You don't need a Dell power supply, pretty much any power supply will do.
If you have a Staples local to you, they are clearing out the Antec EA500 for $50.
Or order something like this
http://www.newegg.com/Product/Prod [...] 6817341022
Reply to delluser1
- 0 +
Hi newcomer and welcome to the Tom's hardware forum.
What GPU you bought?, and make you sure that your case and current PSU is ATX. With a 500W PSU is enough for the rig, make you sure that is from a good brand like Coolermaster, Corsair, Thermaltake, Antec, PC power and cooling or OCZ.
Reply to saint19
When you get a new PSU best to take your old one along to check that the screw holes are teh same.
Some Dell PC's use non-standard PSU's so a normal one will not phsyically fit in the case.
Reply to plasmastorm
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Dell Power Supply Options
There are 2031 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 1 hour ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
