Hello all,
Probably this question has been asked 1003+ times before, but it would be great if you can give your opinion about the following.
The question is if it is possible to run a system with below specs in SLI configuration:
MB: ASUS P6Tv2
CPU: Intel i7 950 3.06 GHz @ 3.60 GHz
RAM: Kingston 3x 2GB PC16000
SSD: 1x 64GB
HHD: 1x 500GB running 7.200 rpm + 1x 150GB 10.000 rpm
GPU: 2x ASUS Radeon EAH 5870
PSU: Coolermaster 700W
Currently one GPU is installed and everything runs fine.
But a second GPU is on its way and I'm not sure about the 700W... so I wanted to know if this will run or not so, if needed, I can order a new PSU.
Thanx in advance !!
Greetz, Bresso
MB: ASUS P6Tv2
SSD: 1x 64GB
Thanx in advance !!
Greetz, Bresso
