Sign-in / Sign-up
120 mm Side panel case fans.
  • Heatsinks
  • Cases
  • Fan
  • LED Monitor
  • Overclocking
  • Product
April 14, 2012 11:22:39 PM
Hey!
I need 2x 120mm fans for the side of my case, since it came without any.
Im not a fan of LED and black would be best (but not necessery)
I would rather go with a quiter fan, but still enough to cool :)
-Thanks!
My case: CM Storm Trooper
More about : 120 side panel case fans
April 15, 2012 1:01:54 PM
http://www.newegg.com/Product/Product.aspx?Item=N82E168... for a little more CFM and noise.
My suggestion, get the second and a fan controller. Then you can leave it low 90% of the time, and when you do 10 hour game session kick the fans up to a higher speed. Even at high speeds it is a very quite fan. I would avoid the the higher CFM scythes, while quiet they still sound like a mini jet engine and it can be distracting.
