Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > Using Poweredge 2600 server as chassis for gaming system
Forum Systems : Homebuilt Using Poweredge 2600 server as chassis for gaming system
Have a Dell poweredge 2600 server, and am researching the feasibility of
replacing its motherboard to build a gaming system. Any feedback on
using the poweredge 2600 server box and some of its components to
do this is greatly appreciated. thanksl
Reply to geospatial
That would probably depend on the configuration of the motherboard tray (ATX, m-ATX, E-ATX) as well as the power supply (whether a replacement would fit).
-Wolf sends
------------------------------ All Purpose System Specs: GA-H55M-S2V Intel CoreI5 760 8 Gig RAM NVidia Geforce 8800GTS-640 Windows 7
HTPC System Specs: ASRock 760GM-GS3 AMD Athlon II X2-240 G.Skill 4 GB (2x2GB) Radeon HD4670 Ceton InfiniTV4 TV Tuner
Reply to Wolfshadw
I actually just replaced a Dell Poweredge 2600 at work not too long ago so I am pretty familiar with that case.
What your doing is possible. However I don't think it gives you an advantage for cooling, cable management or anything like that. Dell's cases (especially the server cases) are very proprietary and are made to fit smoothly with only their fittings. If I remember correctly; that model may have some funky hard drive bay/integrated raid card set up which might make things difficult. You might even find that the Dell case power and LED pin connectors are proprietary in some way and work with only their motherboard!
Unless you specifically want a gaming machine that looks like a Dell server I would just buy a real case.
Reply to njalterio
A good gamer case can be had for around $100? Why bother with this? I looked up the specs and Dell seems vague on whether the thing houses an ATX motherboard/PSU or something proprietary. I'm just not able to discern any tangible benefits for even attempting to go this route.
A 2600 has a worthless (for gaming) CPU, terrible memory (DDR!), horrible video capabilities and is a generally ugly looking case. Unless you're hiding some detail from us, maybe you need to rethink your plan.
Reply to rodney_ws
Oh, and 90 lbs fully loaded? Ha ha ha ha ha. No thanks.
http://www.dell.com/downloads/glob [...] _specs.pdf
Message edited by rodney_ws on 11-19-2009 at 04:11:29 PM
Reply to rodney_ws
There are 1982 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$600 Budget Gaming Build - Advice Appreciated
By coffeecoffee, 5 hours ago:
Alright, your on the right track. There are a few changes I would like to make if I...
Best offers
Top experts
