Also, Do all these parts go together? Am i forgetting something, such as more compression fittings? Thanks!
Pump:
Swiftech MCP355™ 12v Water Pump (Native 3/8") (120 GPH)
http://www.frozencpu.com/products/5125/ex-pmp-47/Swiftech_MCP355_12v_Water_Pump_Native_38_120_GPH.html?id=wjcbnkr2&mv_pc=1509
Resovoir:
EK Dual Bay SPIN Reservoir w/ Flow Meter - Plexi
http://www.frozencpu.com/products/8583/ex-res-145/EK_Dual_Bay_SPIN_Reservoir_w_Flow_Meter_-_Plexi.html?id=wjcbnkr2&mv_pc=1510
Cpu Block: Danger Den DD-M6 Brass and Copper CPU Block - Sockets LGA 2011 / 1366 / 1156 / 1155 / 775 (CPU-601)
http://www.frozencpu.com/products/14954/ex-blc-1047/Danger_Den_DD-M6_Brass_and_Copper_CPU_Block_-_Sockets_LGA_2011_1366_1156_1155_775_CPU-601.html?id=wjcbnkr2&mv_pc=1511
Radiator: Alphacool NexXxoS ST30 Full Copper Slim Profile Triple 120mm Radiator
http://www.frozencpu.com/products/15665/ex-rad-374/Alphacool_NexXxoS_ST30_Full_Copper_Slim_Profile_Triple_120mm_Radiator.html?id=wjcbnkr2&mv_pc=1514
Tubing: 2.5 Meter (8 feet) Feser Tube Active UV Hose - Retail Packed - 3/8" ID (1/2"OD) Anti-Kink Tubing - UV Blue
http://www.frozencpu.com/products/8652/ex-tub-453/25_Meter_8_feet_Feser_Tube_Active_UV_Hose_-_Retail_Packed_-_38_ID_12OD_Anti-Kink_Tubing_-_UV_Blue.html?id=wjcbnkr2&mv_pc=1512
Coolant:
EK EKoolant Premium Liquid Cooling Premix Coolant - 1L - UV Blue
http://www.frozencpu.com/products/14160/ex-liq-190/EK_EKoolant_Premium_Liquid_Cooling_Premix_Coolant_-_1L_-_UV_Blue.html?id=wjcbnkr2&mv_pc=1513
Compression Fittings: 3/8 x 1/2 Compression Fittings Quantity:6
Thank you this all cost around $389 with shipping. Also, Will those compression fittings work with everything?
Pump:
Resovoir:
Coolant:
