APPROXIMATE PURCHASE DATE: (Hopefully within the next month) BUDGET RANGE: (600-800) Before / After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: (gaming, watching movies/tv shows, researching/schooling)
PARTS NOT REQUIRED: (dont need keyboard, mouse or monitor)
PREFERRED WEBSITE(S) FOR PARTS: www.newegg.ca ,
www.tigerdirect.ca ,
www.ncix.com , (probably newegg is the best bet & cheapest, however its canadianness doesnt have much of a selection
PARTS PREFERENCES: Was hoping to go with an AMD Phenom ii x4 955 build at first, but now im debating.. may just go with e8400 and hold off for a while.. still not 100% sure though. Possible even a II x3..
OVERCLOCKING: Possible, but not for a while. SLI OR CROSSFIRE: Not anytime soon.
MONITOR RESOLUTION: Im running 1280x1024 right now
ADDITIONAL COMMENTS: I want best performance & best bang for the buck. GAMING.
Rosewill R5717-P BK 120mm Fan ATX Mid Tower Computer Case,with mesh air filters,adjustable vents & Tool-Free kits
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
Western Digital Caviar Blue WD3200AAJS 320GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
XFX PVT98GYDLU GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B
SILVERSTONE ST56F 560W ATX 12V 2.01 & EPS 12V SLI Ready CrossFire Certified Active PFC Power Supply
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400
& ASUS P5Q Deluxe LGA 775 Intel P45 Intel Motherboard - Retail
http://www.newegg.ca/Product/ComboDealDetails.aspx?Item...
Any tips/Suggestions & advice please let me know! it would be greatly much appreciated! (Still cannot quite make my mind of up about the AMD x4 955BE or what.. can't think without biased remarks >_<)
Games I really play are CS:Source (CS
![:p :p]()
romod when released), World of Warcraft, COD:X, Any new MMO/FPS games that look good, and may be worth the purchase.
