Offset Voltage Overclocking, How to?
- i5-2500k overclocking and offset voltage Forum
- How to use offset voltage? Forum
- Overclocking i5-3570k with offset voltage Forum
- Offset Voltage Overclock HELP!! Forum
- SolvedOc'ing 3770k 4.4ghz, offset voltage question Forum
- SolvedOffset voltage on a 4670k? Forum
- Help with Offset Voltage Forum
- Solved4670k offset voltage question Forum
- SolvedWhat offset voltage is safe for 4.6 Forum
- SolvedASUS P6X58D-E CPU Voltage Control: Manual x Offset Forum
- SolvedOffset Voltage and VID Help 2500k Forum
- Solved2500K Voltage Fixed vs Offset Forum
- SolvedHow far should I raise the voltage of my GSkill Ripjaws 8GB(4GBx2) DDR3 1333mhz if overclocking and reducing latency? Forum
- i5 3570k @4.5ghz offset -0.020, medium CPU LLC, load voltage-1.080V, is this normal? :S Forum
- Solvedhelp with offset voltages Forum
- SolvedHow important is PCH Voltage overclocking? Forum
- i5 3570k to 4.2ghz Offset voltage advice... Forum
- CPU offset voltage not working properly...? Forum
- offset voltage for 4.2Ghz i5-3570k Forum
- An issue with offset voltage Forum
- More resources
Read discussions in other Overclocking categories
Well at least with fixed voltage It doesn't get stable until 1.45v which is VERY high. I heard overclocking with offset can be better though, as voltages are lowered? Is there a guide to this? I currently an using 4ryan6's guide and everything is the same, except core current limit is 200.
