Hi
I have a home network, with a 100Mbps switch.
to this network I have connected two computers.
But as I frequently have to make large transfers between them I'd like to connect them directly thought their gigabit nics with a cross cable (cat 6).
I've assigned The IPs in different networks so windows won't get confused.
But even if I try to connect to the other one through it's IP (the Gbps) instead of the network neighborhood it always chooses the 100 Mbps connection to make the transfer.
How can I force the connection between this computer to always go through the Gbps?
thanks in advance
thanks in advance
