Hi Lads,
I have x2 NB fans in a push/pull config. I've put em in respectively CPU_Fan, and System_fan_2 which should both be PWM controlled, and both have 4 pins!
The problem is, that CPU_Fan is working like a charm, but the system fan 2, is spinning away like a mad! I tried to work around in Easytune, but with no luck! Only thing I can, is to use Smartfan to decrease the speed - but then I lose the PWM feature.
So what I want, is the system_fan_2 to follow CPU_Fan in RPM, and stays in PWM mode! Is there any way to do this? Easytune appears not to be working, since it only affects CPU_Fan!
