So, I recently upgraded my motherboard and CPU, and in the process, altered my water cooling loop. For some reason I seem to be having trouble getting the pump to run and I get intermittent CPU fan error warnings on POST. I have an Asus P9X79 Deluxe mobo, and my loop consists of an XSPC dual-bay reservoid to a MCP35X pump, to a Swiftech Apogee HD CPU block to a 3x120mm radiator and back to the reservoir. The pump has a 4-pin molex connector and a 4-pin fan connector that's plugged into the motherboard. Even when I was just test running the loop, I would notice that sometimes the pump wouldn't be running and sometimes just shutting it down and starting it back up would enough to get it running. Anyways, this is really frustrating, and I'd appreciate any advice.
P.S. PSU is a Corsair AX1200 (1200W). Rest of my specs in the sig.
