So i really couldn't find a category to put this in, since im not really sure where the problem is...but here goes nothing,
So i did post something last not (kinda related to something else) but since i found a new problem, i'd figure id make a new post.
So i installed a CM Hyper 212 plus to replace my stock intel cooler.
my PC specs are:
i7-920 (w/ 212+)
GA-EX58-UD3R
6gb Corsair DDR3-1333mhz ram
640gb WD Caviar Black hdd
HD4850
CM eXtreme 500w PSU
PCI Wireless card
5 case fans (3 red led CM, 2 stock antec tricool)
Antec 300 Case
After i installed my new heatsink, i tested it out, but my PC wouldn't boot up any image onto my monitor, but it would still turn on, i removed all the ram, and it made 1 "bzzt/beep" sound.
i tried removing the 3 CM case fans, still didnt work, so i removed the fans AND 4gb or RAM and it worked. so now i have to run my PC with 2 gb's of ram or it won't run.
is this a Power supply problem? im pretty sure the power plugs are in correctly...i just find it strange how it could run everything before, but now i have a new heatsink and that caused the problem.
on the brightside, my cpu runs 10 degrees cooler idle...lol..
my PC specs are:
i7-920 (w/ 212+)
GA-EX58-UD3R
HD4850
CM eXtreme 500w PSU
PCI Wireless card
Antec 300 Case
