Hey guys, as you will see in my picture, my general theme is white/blue/black with white being the dominant color, blue being secondary and black being an offset of sorts. I want to change all my 120mm (which include the cpu cooler fans)(and the single 140mm if possible) to the same exact style. I want them to match my current scheme. I will show you some options I have come up with and hopefully the community can provide me with some other ideas.
First, my rig:
Next, I found these fans on xoxide and they go well with my color scheme, but some of them are not optimal with airflow-no LED-low rpm.
http://www.xoxide.com/kingwin-screw-less-120m-durobearing-black-white.html
http://www.xoxide.com/kingwin-screw-less-120m-durobearing-white-blue.html
http://www.xoxide.com/xigmaetk-xof-f1251extremeoctogon-120mmcasefan.html
http://www.xoxide.com/zalman-zm-sf3-fan.html
http://www.xoxide.com/logisys-sf120-rubber-fan.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233046
Any insight or opinions?
I would also like to change my sata cables, 24pin, 8pin, etc etc to a sleeved set (either pre-made or I will sleeve myself). Anyone have any ideas on those?
First, my rig:
