Need Power supply help!
I am going to build a new PC, config will be
Core i7-920
Gigabyte ex58-UD5
Corsair 12 gb ddr3
ATI 5970
GTS 250 as PHYSX (If i get GTX 480)
Cooler Master HAF 932
I think the upcoming GTX 480 will Consume same power as of ATI 5970 or more than that. I will use my current GTS 250 as physx processor.
Please Recommend me a good PSU.
2 answers Last reply
More about need power supply help
  1. Corsair 850HX
    Seasonic M??? 850 (Don't remember the exact model number but it is the new 80Plus Gold model)
    Antec SG-850
    Corsair 850TX
    Corsair 750TX
    Anyone of those five will be strong enough for your setup.
  2. Here are the official power requirements for the ATI Radeon™ HD 5970 video card.
    ATI Radeon™ HD5970 System Requirements:
    PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
    650 Watt or greater power supply with one 75 watt, 6-pin and one 150 watt, 8-pin PCI Express® power connectors
    850 Watt or greater power supply with two 75 watt 6-pin, and two 150 watt, 8-pin, PCI Express connectors for ATI CrossFireX™ technology in dual mode
    The power supply recommendations are for an entire pc system.
    The new Corsair HX850, Silver Certified power supply would be an appropriate choice:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
    Corsair has a reputation for high quality power supplies. They consistently earn high marks in technical reviews. They are very stable and reliable. The HX850 comes with an excellent 7 year warranty.
    Here is a link to a technical review:
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=153
Power Supplies Components Product
