Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > DVI problems - sparkles, flashes, blurs - why?
Forum Graphics & Displays : Graphics Cards DVI problems - sparkles, flashes, blurs - why?
Hey friends,
so I built a new pc today running Windows 7.
Case in point:
XFX 4890 1GB
Samsung Syncmaster T190
I bought a DVI cable, came home botted it up, and I see pixels sparkling on the Asus bootup screen and on the Windows 7 loading/progress dialog thing. In the desktop, green and red sparkles can be seen in various places on the desktop photo.
Also if certain coloured pixels are present over certain areas of the screen, the monitor flashes on and off slowing - much the same as if you are constantly changing resolution (but its not).
Text is also blurry in places - towards the center of the screen.
Reducing the resolution from native clears up all problems seemingly although text is still a bit blurred but at least I can see what I'm looking at enough to type this thread!
Not sure if its the card, the cable or what. Its obvious that its a hardware problem because its visible outside of windows (bootup). :o
I'v been using the monitor in VGA mode for 3 months now and it displays fine in that mode. Its a high end spec, so I'm thinking that its either the cable or the video card.
Wondering if anyone has experience with something similar? How can I fix this?
How can I change the DVI port in windows? I plug the cable into the second port, but the monitor doesn't pick it up. Is there a setting or something in catalyst control center that I need to change? I looked but can't find one.
Thanks.
Reply to delatroy
I had something similar happen to me and it ended up being the new dvi cable i got on ebay..I bought 2 of them and both did the same thing, crazy stuff on my monitor..I went and got a dvi cable on another pc i have, and as soon as i used it my problem was gone..hope it helps
Reply to guitarsrule1970
There are 1878 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
7970 vs 670
By yougotjaked, 43 minutes ago:
I do video/photo editing and 3D modeling and I haven't had any problems. You could wait...
Best offers
Top experts
  • diec4st
    diec4st - bronze Expert
    Specialties : Graphics
    267 messages since 1970/01/01
  • pro-gamer
    pro-gamer - bronze Expert
    1598 messages since 1970/01/01
  • jyjjy
    jyjjy - bronze Expert
    10077 messages since 1970/01/01
