Overclocking e5200 g41 es2l problem
Hi guys, i wanted to overclock my cpu to 3.6ghz, i have the stock cooler.
ca you please tell me the parameters for the cpu?
i have windows 7 ultimate
CPU
Processor -----------------------------------------------------------------
Processor Manufacturer: Intel
Processor Version: Pentium(R) Dual-Core CPU E5
External Clock: 288 MHz
Motherboard ---------------------------------------------------------------
[Computer]
Computer Brand Name: GIGABYTE G41M-ES2L
[Motherboard]
Motherboard Model: GIGABYTE G41M-ES2L
Motherboard Chipset: Intel G41 (Eaglelake) + ICH7
memory
Device Size: 2048 MBytes
can you please tell me the frequency that i should put and the voltages?
Fixed your post.
John
Overclocking Master
CPUs Master
Unfortunately, overclocking does not work that way. Two CPU's cut from the same wafer can have different characteristics. So what we do is provide guides, not cookbooks.
And we have one for you. :)
Shadow's Gigabyte motherboard OC guide:
http://www.tomshardware.co.uk/forum/page-245679_11_0.ht...
It's for an EP35-DS3L but all the Gigabyte Core2 BIOS's are similar. The G41 will just have fewer settings.
Go through the guide. Then take your core voltage off Auto and set your memory voltage to factory recommended values. Change the System Memory Multiplier from AUTO to 2.00 (or 2.60 if that is the lowest setting). Then when you increase the FSB, the memory clock will rise in in proportion with it. At an FSB of 200 MHz, your memory clock should be at 400 MHz (520 MHz if SMM is 2.60).
Now start the overclock/test cycle.
Stop when:
1. The CPU will not go any faster, or
2. Core voltage reaches 1.45 volts, or
3. Load temps reach 70 C.
The stock cooler will be your first limiting factor. With just a mediocre cooler (all you will need), you should be able reach around 3.6 GHz. Some E5200's will run at 4 GHz with stability.
Ask the community
