muhammadbinmehroze Honorable Apr 24, 2012 247 0 10,710 May 1, 2012 #1 hi guys.. can THERMALTAKE CONTAC 29 120MM (CLP0588) be attached to intel dh61ww mobo?
Solution T T tekman42 May 4, 2012 YES you can use it although the compatibility states socket 1156...look here http://www.newegg.com/Product/Product.aspx?Item=N82E16835106141 read the reviews and you will see it being used on core I-7 also look here for socket description and comparison for socket 1155 & 1156 http://www.teamliquid.net/forum/viewmessage.php?topic_id=194500 SHOULD BE GOOD TO GO. Respectfully, tekman42
T tekman42 Honorable Feb 22, 2012 226 0 10,760 May 4, 2012 Solution #2 YES you can use it although the compatibility states socket 1156...look here http://www.newegg.com/Product/Product.aspx?Item=N82E16835106141 read the reviews and you will see it being used on core I-7 also look here for socket description and comparison for socket 1155 & 1156 http://www.teamliquid.net/forum/viewmessage.php?topic_id=194500 SHOULD BE GOOD TO GO. Respectfully, tekman42 Upvote 0 Downvote Solution
muhammadbinmehroze Honorable Apr 24, 2012 247 0 10,710 May 4, 2012 #3 Best answer selected by muhammadbinmehroze. Upvote 0 Downvote
