I've been going between the new 9.11,9.10 and 9.9 drivers, trying to figure out what my problem was in Crysis when I used AA at any level. I figured out it was indeed the new 9.11 drivers causing the weird AA issue, so I then figured why not see if it is for sure the drivers, so I used Driver cleaner pro to uninstall them and CCleaner to clean out the registry. Then I installed the 9.11 drivers again and at 1st while in Crysis while using 8x AA it all seemed fine but then I started to see the artifacts again (its not an OC/Heat issue) so I again used DCP and CC an installed 9.10 drivers hoping I could just use those till the next set came out . Now heres my real issue I know that 9.10 was stable for me an worked well but for some reason now CCC will not load up at all as I keep getting this error every time I try to restart the CCC runtime.
Error:
Could not load file or assembly 'MOM.Implementation, Version=2.0.3349.40275, Culture=neutral, PublicKeyToken=90ba9c70f846762e' or one of its dependencies. The System cannot find the file specified.
Same thing also happens with the CLI.Implementation
Error:
