I bought a 3TB hard drive to use for storage (not booting) on my system. when i went to format it windows is only seeing 746.39 GB. I'm using GTP to format. This drive is replacing a 2TB drive which i had no problems with. My BIOS is updated to the latest release. After some research on TH and google, i know the 3TB drives can be tricky, but since I'm only using it for storage I'm not sure what the problem is. I tried to proceed and partition the disk hoping it would eventually recognize the unused space but it didn't. Right now "Disk Management" only shows 746.39 GB of unallocated space. I downloaded a trial version of Paragon Software to see if the could recognize the space, but it only saw the same 746 GB.
Hopefully someone has solved the problem and could clue me in.
Here's my system info:
Windows 7 x64
ASUS P5N-D motherboard (latest BIOS)
Western Digital Caviar Green 3TB HDD (replacing a WD Caviar Green 2TB HDD)
Thanks in advance.
-Ted
Windows 7 x64
Thanks in advance.
-Ted
