I5 build. Parts compatible? Suggestions welcome
APPROXIMATE PURCHASE DATE: Within the next few days
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Some gaming, school
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS
PREFERRED WEBSITE(S) FOR PARTS:
PARTS PREFERENCES: by brand or type
OVERCLOCKING: Yes (Mild overclocking) SLI/CROSSFIRE: NO
MONITOR RESOLUTION: 1600x900
ADDITIONAL COMMENTS:
Hello. I am currently trying to build an i5 system which is my very first build. This is a build that I put together. Could you guys make sure to see if all the parts are compatible with one another? Also I am not sure what motherboard and gpu I should get. Is the gigabyte ud2 a good and reliable board? If you guys have any suggestions about the build that would be great. Thanks.
CASE: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128405
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130240
GPU: I am not sure whether I should get a 4890 or a 5770.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125297&cm_re=4890-_-14-125-297-_-Product
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231275
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Optical: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136167
1 answer Last reply
More about build parts compatible suggestions welcome
Build Intel i5 Compatibility Systems Product
