Solved
Advice on xfx power supply
I am building an i5 computer going to do some overclocking nothing too crazy probably 3.6ish or less and I have all my parts set for the most part. The only thing that worries me is this power supply.
XFX P1-750B-CAG9 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
Saw it in a combo deal with xfx graphics card which was 60 bucks off so it was a very good deal. Does this look like a good psu to you guys? I am not that up to date with new psu's and the reviews on this are sparse and hard to find. Any help would be appreciated....here is the rest of the build...
XCLIO Windtunnel Fully Black Finish 1.0 mm SECC Chassis ATX Full Tower Computer Case
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm
XFX HD-587A-ZND9 Radeon HD 5870 (Cypress XT) 1GB XXX Edition 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 - Retail
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel Motherboard - Retail
Item #: N82E16813131405
total
$1,197.92
4 answers Last reply Best Answer
More about advice power supply
  1. The XFX P1-750B-CAG9 750 watt Black Edition is a brand new power supply that earned a silver certification for energy efficiency. It was manufactured by Seasonic for XFX. You should not have any problems with it.
  2. Best answer
    As Johnlucky said, the new XFX supplies are manufactured by Seasonic....which are absolutely fabulous, running a 430W Modular Seasonic PSU in my machine and its the best $65 I've every spent.
    You could probably get away with 100W less...frankly even that system wont use more than 300W at any given time, and get a 650W Seasonic X650 Gold, the same PSU in JohnnyLucky's machine...and you can trust him. It is certified for 80 Plus Gold...extremely efficient.
    The XFX supply isn't a bad supply for the money though, as its still $20 cheaper than the seasonic 650W Gold supply.
    Long story short: Sounds good.
  3. Ok thanks a lot it wasn't my first choice but I am saving 100 bucks by getting that with the 5870 so I just wanted to make sure it was up to task. Appreciate it guys.
  4. Best answer selected by adramaleck.
Power Supplies Components
