Solved
Built my PC but dont know how to overclock, NEED HELP!?!?
  • Overclocking
May 4, 2012 11:07:26 PM
I know how to go through the bios and everything but im just confused on the voltage or wattage part of overclocking and knowing what to disable and enable. I built the PC myself took me like 7hrs and been using it 4days so far. Can you guys check out my specs and help me out?
EDIT: Here are my Specs:
Intel Core i5-2500K
BIOSTAR TZ77B
ZALMAN CNPS9500
NZXT GAMMA Case
HIS Radeon HD 79503GB
G.SKILL 8GB DDR31600.
RAIDMAX HYBRID 2 RX-630SS 630W
Windows 7 64-bit
EDIT: 05/11/2012:
I blew out my PSU a couple of days ago overclocking, LOL! But, bought a better one. It's a OCZ 750watt.
More about : built dont overclock
a c 428 K Overclocking
May 4, 2012 11:33:07 PM
This topic has been moved from the section CPU & Components to section Overclocking by Area51reopened
m
l
Best solution
a b K Overclocking
May 16, 2012 4:02:10 AM
http://www.tomshardware.com/forum/265056-29-2600k-2500k...
for sure don't go over 1.5 vcore and don't let the cpu temps over 75c
May 16, 2012 4:10:29 AM
Get into your BIOS and bump up your multipliers. Step it up and do testing with prime95, intel burn test, cpu-z and HWmonitor. Good luck!
m
l
May 26, 2012 12:37:51 AM
Best answer selected by ticklemelmo.
m
l
