Help me with this strange annoying problem
Last response: in CPUs
Anonymous
CPUs Authority
Hi everyone, I have had this problem almost since I had bought the PC, it worked fine once and but decided to change.
The problem is that the CPU fan is running at full throttle from the second that I push the power button.
Specs:
ECS nforce4 939
Amd x2 4200
2x512 ddr
500w power suply
250gig HD
7600gt Nvidia
I have gone thorugh countless hours of reading and searching but never found anything.
Yeah, and here is why I said it was a STRANGE problem:
If I go ahead and open the " Nvidia control panel" and do nothing else but opening it, the rpm of the CPU slows down automatically as the control panel loads up, I have now to do that everytime I start the system, but what is this really about?
in bios the CPU temperature is "ZERO" . something is wrong with the sensor? but how
thanx
Kalle
Anonymous
CPUs Authority
AMD Athlon 64 X2 Dual-Core 4200+ (E4) 2200 MHz (1MB,2000,Socket 939
not sure about the mobo and bios version but it is from 2006, gonna check it at startup
Ask the community
