Going to make this very simple and easy to answer.
Will this CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103702&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Processc3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Processors+-+Desktops-_-AMD-_-19103702
Work on this Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130270
And I believe cpus are also called chipsets so I put that under sub cato, correct me if i'm wrong.
Thank you for your time.
