Solved
Will a antec true power quatro 100W psu fit in a coolmaster scout
Last response: in Components
Best solution
The PSU will fit into the Cooler Master Scout. It is the Antec CP-1000 is the one that only fits specific Antec cases.
One question... Why do you need a 1000 watt PSU over say the Antec EA 750?
awesome thanks for the help i have been using your stp-by step guide to build my own computer, your advice is awesoem you should consider work as a tech specialist!!
Related ressources
Thanks... If I ever have to make a career move, it will be my first choice. For now, I'll stick to the quality assurance world.
I updated my original post to ask why do you need a 1000 watt PSU? Most builds will not required more than 850 watts and even less if you don't plan on Crossfire/SLI.
Ask the community
