does havening a integrated card along with your external effect performance in any way. ie do they work together similar to crossfire or is the integrated one basicaly turned off while its powerfull cousin takes the reigns.
It's either one or the other, except in the case of Hybrid Xfire from ATI, which is only usable with a certain mobo and specific cards, not likely to happen accidently.
