Solved
Higher speed memory working with lower speed motherboard?
My question, in its most distilled form: does this memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231282
work with this motherboard
http://www.newegg.com/product/product.aspx?Item=N82E16813157196
From reading different articles on Tom's Hardware it seems like memory with a higher speed will simply be recognized as have a lower speed on a motherboard rather than not working at all. Since I don't trust my inference i figured I would ask the question outright.
If this memory doesn't work then I hope someone can recommend the best memory for this motherboard. Thanks a lot!
Also, I'm sorry about the Sub-category, but I didn't know which one to chose.
2 answers Last reply Best Answer
More about higher speed memory working lower speed motherboard
  1. Best answer
    Yes it will work, to get the best out of it you will need to set the speeds manually in the bios.
  2. Best answer selected by jbf81tb.
Chipsets Tom's Hardware Motherboards Memory Product
