Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Toshiba recovery CD problem "Extraction failed"
Forum Laptops & Notebooks : General Laptops & Notebooks - Toshiba recovery CD problem "Extraction failed"
Archived from groups: comp.sys.laptops (More info?)
Hi --
When trying to sweep clean my Toshiba laptop by reverting to the factory
configuration using the recovery CD, I encounter the following error
message:
"ERROR! Extraction failed"
Nothing works from this point on.
Does anyone have an idea? All input will be highly appreciated.
Regards
Anne Highsmith
Sponsored Links
Hi Anne,
It sounds like you have an 'image' disk rather than an 'OS' disk. If this is the case, you will have to have the disk replaced.
Most manufacturers will do a replacement for a nominal fee.
If your disk is an OS disk, does it tell you what file can't be extracted?
Ciao . . . C.Joseph
That which a man buys to cheaply . . .
He esteems to lightly
Anne Highsmith wrote:
> Hi --
> message:
> Regards
> Anne Highsmith
Reply to Anonymous
There are 480 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
