Is my ram running at correct default speed?
its two 4gb kingston chips that are 1600mhz
i have a core i5 2550k and asrock z77 extreme4
Im kind of worried that it says max bandwidth pc3-10700 667mhz
I have XMP enabled.
this is cpu-z of it
CPU-Z TXT Report
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Kingston (7F98000000000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number KHX1600C9D3/4GX
Serial number 650F7B16
Manufacturing date Week 10/Year 12
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.2
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-25-34 @ 685 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.650 Volts
Min Cycle time 1.250 ns (800 MHz)
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 45.00 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-6-6-18-24-0T @ 533 MHz (1.650 Volts)
XMP #2 7.0-7-7-21-28-0T @ 622 MHz (1.650 Volts)
XMP #3 8.0-8-8-24-32-0T @ 711 MHz (1.650 Volts)
XMP #4 9.0-9-9-27-36-0T @ 800 MHz (1.650 Volts)
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Serial number 870F823D
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 45.00 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00
10 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 01 98 04 12 10 65 0F 7B 16 2A F0
80 4B 48 58 31 36 30 30 43 39 44 33 2F 34 47 58 20
90 20 20 00 00 80 AD 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0C 4A 01 12 01 08 00 00 00 2D 0A 5A 3C 00 50 5A
C0 5A 78 11 0E 68 3F 00 00 05 3C 30 00 F0 3C 00 00
D0 00 00 24 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5A
DIMM # 2
SPD registers
70 00 00 00 00 00 01 98 04 12 10 87 0F 82 3D 2A F0
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CPU-Z TXT Report
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 45.00 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 33.75 ns
Min tRC 45.00 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
DIMM # 1
SPD registers
DIMM # 2
SPD registers
6 answers Last reply
More about running correct default speed
  1. make sure you that you select XMP profile #4
  2. Speeds are multiplied because of DDR, which stands for Double Data Rate.
  3. I only have xmp 1.2 profile 1 in the bios thats the only one listed.
    I changed DRAM Freq to DDR3-1600mhz
    On the Memory tab in cpuz its saying 800 mhz which if its doubling should be correct
    Although on the SPD tab slot 1 and 3 say pc3-10700 (667mhz)
    it gets a lower rating in windows test than my gskill ram in other computer which
    is 8gb 1600mhz also. :( thats why i started looking into it in the first place to make
    sure that its running correctly.
  4. Yes, if Cpu-z shows it as 800MHz it is working at 1600MHz, you're fine there
    Moto
  5. ok I reran windows assessment and the RAM score went from 7.6 to 7.8 so I think that did it, thank you guys for your help :D
    although it still saying max bandwidth is 667 mhz in slot one idk whats up with that
    but i dont know much about ram speeds either really, thanks for your help
  6. Glad to reassure you man,
    Moto
Memory Overclocking
