.Hey guys, ill keep this short as im on my phone.
Im trying to instal an ek fc block on my 680 and something is wrong. The block just doesnt seem to fit my card even though i have a reference asus card.
All the holes line up, but the supplied screws dont reach the pre installed standoffs. The capacitors on the board seem to be too tall, so the screws just dont go far enough. Even if i use a longer screw ( i tried a long on provided for the pci bracket( it just means the pcb ends up flexing horribly because the capacitors force a part of the board higher thrn the rest.
Really annoyed atm, as my pc is sat in pieces and i bought the damn block from usa, so its pretty much pointless returning it.
So does anyone have experiwnce with these blocks? Im pulling my hair out.
