Just wanted to see how I did for my first time build. Will be used for mild gaming, movies, and CAD type work.
Cost me roughly 1300 total.
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215&cm_re=i5-_-19-115-215-_-Product
GIGABYTE GA-P55-UD3R LGA 1156 Intel P55 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128401&cm_re=ud3r-_-13-128-401-_-Product
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
LG Black 8X BD-ROM 16X DVD-ROM 40X CD-ROM SATA Internal Combo LG Blu-ray Reader & 16X LightScribe DVD±R DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136162
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=hyper_212-_-35-103-065-_-Product
DIAMOND 5850PE51G Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814103085&cm_re=5850-_-14-103-085-_-Product
I will be using 2 of the following monitors
Acer H233Hbmid Black 23" 5ms HDMI Full HD 1080P Widescreen LCD Monitor 300 cd/m2 40000:1 (ACM) Built in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009162&cm_re=h233h-_-24-009-162-_-Product
Also picked up a DeathAdder mouse for like $15 and have just a generic keyboard for now.
Does this all look good for moderate gaming or is there anything I should change or add?
Also what is a good gaming keyboard?
