Solved
Need A good Power Supply
Looking for a power suply that can power all this and I would prefer a dual fan system on the power supply
Mother board is an ASUS P5QL Pro
5 Fans
4 hard drive's three of them are SATA & one of them is IDE.
1 IDE DVD Player
1 SATA Blue Ray Player
& an ATI 4850 Grphics Card
Im curently using a realtek 550 watt PSU and I have to unplug my IDE DVD drive to use all 5 of the fans so Im looking for a good modle that can power evry thing in the system & I'm Thinking of a 650 to 750 watt PSU any IDeas
12 answers Last reply Best Answer
More about need good power supply
  1. I recommend the Antec TP-750 or Corsair 750 TX.
  2. If you are never going to put a second video card in your computer, something like a 650 watt Corsair or Antec will be more than adequate.
  3. OK just answered this 3 times already tonite:)
    http://www.tomshardware.com/forum/270870-28-trying-decide#t2017746
    http://www.tomshardware.com/forum/275514-31-1156-cooling-advice-10pm-hardware-time
    Go to this link and let it "do the math" for you.
    http://www.antec.outervision.com/
    Go to this link and read some of the reviews:
    http://www.silentpcreview.com/Recommended_PSUs
    2 GFX Cards and aggressive OC'ing
    Antec SG-850
    Corsair HX-850
    1 GFX card and aggressive OCing
    Antec SG-650
    Corsair HX-650
    2 GFX Cards and light OC'ing
    Antec TP-750
    Corsair TX-750
    1 GFX Card and light OC'ing
    Antec TP-550/650
    Corsair TX-650/VX-550
  4. I would change the Antec TP-550/650 for an Antec Earthwatts 650. Other than that those are great suggestions.
    Why ?
    The TPN 650;
    1] Provides up to 54 amps of 12v power to the EA's 45a.
    2] Is more efficient.
    3] Has greater upgradeability ( 4 x pcie power connectors ).
    4] Is semi modular ( and sleeved ).
    5] Is on sale ( at Newegg ) for the same price as the EA650. The 750 Blue is the same price after rebate as well.
    Don't get me wrong, I'd have no problem using the EA, but they are 2 different classes of psu and at the same price the TPN is a much better option.
  6. Best answer
    delluser1 said:
    Why ?
    The TPN 650;
    At the same price you are right there is no question that the TPN is better but usually that is not the case so I always will recommend the Earthwatts. By the way Frys had it on sale yesterday for $30 after $20 rebate.
  7. Well I’m thinking of going with the 750 watt Antec PSU because I am going to put more hard drives in my system in the not so distant future so the 650 watt PSU is going to remain on the side lines I think the extra 100 watts is going to assure there are no problems in the near future. And the reason for going Antec instead of corsair is Because I have an antec 200 gaming case so the antec PSU will go good together although you never see the power supply unit anyway and no I will only have 1 GPU card at a time because my system is a HTPC so I have no need for SLI or Crossfire system. Thank 4 the help so if you know the model number on an antec 750 watt PSU with 7 SATA power connectors one PCIE 6 prong power connector for GPU’s & 7 Normal power connectors like the ones for the old IDE hard drive it would be greatly appreciated thanks.
  8. ragsters said:
    Damn, that is good.
    The way they bounce the pricing around is insane, the 650 is now $110 :ouch:
  9. I got a corsair 800 watt PSU
  10. Best answer selected by Michael775.
Homebuilt Power Supplies Power Systems Product
