Need to upgrade my system
I finally need to upgrade or in this case get a new system put together but im on a college student budget.
My price range is $500-650, the lower the better of course.
Im currently looking at:
Intel Core i5 750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor ($199)
GIGABYTE GA-P55-UD4P LGA 1156 Intel P55 ATX Intel Motherboard ($170)
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 ($125)
And crossfiring 2 SAPPHIRE 100245HDMI Radeon HD 4850 ($115 each)
Im looking to play games like he Witcher, Crysis, Fallout 3 etc. and this setup looks like it would be more then powerful enough to handle it.
This is actually $80 over my price range but it looks like a good investment but at the same time I need to get a new PSU to power this system so if you could post any ideas you have for a good system for less that maybe includes a PSU price to power everything it would be really helpful.
11 answers Last reply Best Answer
More about need upgrade system
  1. Best answer
    Hmm for a budget gaming solution best go with a single GPU solution and here is a suggested config with an 80+ 650 watter included - perhaps a HD 5870 down the road?
  2. Yeah but for the prices the dual GPU can outperform even some of the newer top GPUs for like 1/2 or 1/3 of the prices. But that is a really good setup and in my price range, thanks.
  3. You are welcomed I would also recommend the CM Hyper 212 HSF later down the road if u feel like a wee bit of clocking aye :P
  4. Just realized 4850s are hard to get a hold of anymore so whats the general opinion on just using 2 XFX Radeon HD 4870 512MB PCIe DDR5 Dual DVI for this setup instead of 2 4850s?
  5. I would say stick to single GPU solutions - the thought of buying not one but two previous gen cards when HD 5000 series is out does not seem like a good idea for me hehe
  6. Odd I asked this question just 2 months earlier and everyone on the forum said the 4850 was well worth the price tag.
  7. At one time one could land a HD 4850 for $95 i remember
  8. Thanks thats a big change in price as its now about $20 more.
    I like this build and think im going to go with it, but ill change the PSU to the
    OCZ ModXStream Pro OCZ600MXSP 600W which sells for just $30 after rebate
  9. Yes funny that a 600version of this line is chaeper than the 500 hehe Ya go for it ^^
New Build Systems
