Alright, so before anyone asks, I have been reading up on this issue for about 4 hours now, and I cannot find a solution to what is going on. Here is a quick view of my setup:
768x-ud3h-b3 motherboard
i7 2600k
8gb of ram
3 hdd
1 OCZ Agility 3 120gb SSD
PNY GTX460
A dvd drive ^_^
So for the problem, and what I have tried. The ssd write speeds are extreamly low (or i think they are low), they range from 150 mb/s to 203 mb/s.
I have, updated my bios, re installed all of my motherboard drivers, except a Intel driver you have install when pressing f6 (dont know how exactly to do this), I have went from the Marvell sata 6 to the Intel sata 6. I have went from achi to ide, and back, same thing. I have updated the ssd firmware to 2.15. I have tried resetting all bios settings. Trim is enabled. Also I do not run windows off this drive, just wanted to use it for games to decrease load times. I do not know what else to try, if someone could please help me I would really appreciate it. Thank you in advance.
Also a pic of the benchmarks.
http://i.imgur.com/Rc472.jpg
i7 2600k
8gb of ram
3 hdd
PNY GTX460
A dvd drive ^_^
