Solved
Adjusting Graphics Card Fan Speed
Hi friends,I need some expert opinions regarding video card fan speeds.Is it advisable to max out the fan speed at 100% during gaming?If maxed out[As I am doing now],is there any ill effects for the card?.Does it damage the fan motor?I have an XFX Geforce 8800 GTS card.I am using EVGA Precision to max out the fan speed.....
7 answers Last reply Best Answer
More about adjusting graphics card speed
  1. It should be fine to run full speed it is better to have good cooling than not to have enough cooling. Changes are that you will have upgraded to a new card before you have used up the life of the gpu fan.
  2. Yea you are fine, I raise my fan speed every day.... You should not have to raise the fan to 100% unless it is too hot at a lower speed. Check your temps and adjust the fan accordingly =)
  3. You can run at 100%, it will just be loud. It does wear on the fan a little, but honestly for as long as anyone keeps video cards anymore, it won't go out in the time you own it, unless there are issues.
    I always stick with the stock fan profile unless it is either (a) to loud for me at idle, or (b) I am OCing and need it cooler at higher clocks. In either case, I stopped doing this manually a while back with a fan controller or manual software. Just setup a fan profile in Riva Tuner or another program.
  4. Thank you guys for your opinions.By default for NVIDIA cards,the fan speed is 60%.I have tested the fan speed variations using EVGA Precision during gaming.There won't be notable increase in fan speeds unless the GPU temperature is above 85 degrees.I think anything above 80 degrees is really hot,isn't?.At 100% fan speed,the GPU temperatures settles well below 75 degrees.But I am also afraid of the life of the fan.Does anybody know the average life of a GPU fan or the card itself?
  5. Don't worry about the fan, as long as you take care of your card and remove the dust you should be fine. I have fans that have lasted 4/5 years and to this date they are still working.
  6. Best answer
    According to nvidia max temp for your GPU is 105C that is the reason the fan is programmed as is. Most people that worry about GPU fan speed upgrade every 2 years so it is hard to tell but I have a 5+ year old FX5900 card in my win 98 system that still works fine.
  7. OK,I am satisfied with all the answers.Thank you very much....
Graphics Cards Fan Fan Speed Graphics
