Hello guys,
I'm kind of a computer noob and I just started building my own computer.
CPU:Intel Core 2 Quad Q9550
Memory: Corsair 4gb (2x2) 800 mhz
Motherboard: GA-EP45-UD3P
1 DVD drive
1 HDD - WD 320 gb
GFX: Diamond Radeon 4870
PSU : 500W ATX12V Power
I'm having some problems with it:
1. I play Dragon Age Origins, sometimes out of nowhere the display just goes black and the video card's fan gets noisy, what's the problem with that? Sometimes the game hangs which opts me to alt+f4 and shut the computer down safely and sometimes it just freezes. The 4870 is a powerful card and it needs 2 6-pin PCI-E plugs to get it working, is the problem here my PSU? Should I upgrade it?
2. I'm using an LG 18.5 inch LCD monitor, sometimes the BIOS procedure (the black screens with the BOOT setup thingy when you start your computer) does not show and the only thing the monitor would seem to work is when the Desktop part is fully loaded, why is it like that?
3. I'm currently in the Philippines, its still pretty hot here, i got 3 fans on my case, 1 CPU fan, and the video card fan AND, i leave my computer case open so that it could be well ventilated. What would happen if my 4870 gets insanely hot? Like around 80 degrees? because the normal temperature of this card is at around 55 - 57 degrees.
1 DVD drive
1 HDD - WD 320 gb
