Hi everyone! I was hoping someone could help me with a little problem I'm having..
I'm planning on buying all the parts I need to build a pc either tonight or tomorrow to catch the cyber monday deals on Newegg.. I realize it's a little late to ask but I was hoping you guys could help me anyways
I appreciate any help I can get on this!
I've already got most of my parts selected I just have a couple problems because I'm pretty new to all this.. This is my first pc build and I've never had a pc of my own before
But I'm getting one now so it's all good!
I'm planning to spend between $900 to $1000.. I don't want to go over $1000.. I'm actually trying to stay at just around $900.. I figured you all know more about this than I do so you would know what I'd need..
Here's the build so far:
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard:
EVGA 512-P3-N871-AR GeForce 9800 GTX+ 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card:
(2 sets of this so 8gb's in total) Patriot Extreme Performance 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory:
Western Digital Caviar Green WD10EADS 1TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive:
Rosewill RK-7300 Black USB Super Slim Unique Curved Design Multimedia Full-size Keyboard:
Logitech MX518 8 Buttons 1 x Wheel USB Wired Optical Gaming Mouse:
Pioneer CD/DVD Burner Black SATA Model DVR-218LBK LabelFlash Support:
TRENDnet TEG-PCITXR 10/ 100/ 1000/ 2000Mbps PCI Copper Gigabit Network Adapter:
ALTEC LANSING VS2521 28 Watts 2.1 Speaker System:
Combo deal:
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
1)Intel Core2 Quad Q9400 2.66GHz LGA 775 95W Quad-Core Processor Model BX80580Q9400
2)COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
As you can see all I'm missing is the power supply and the monitor.. I simply don't know anything about choosing power supplies so I was hoping someone could help me choose a good one for this build that's at a good price.. As for the monitor, I'm hoping I can use my tv instead... It's an LG 37" 1080p (model: 37lh30) Here's the link:
Will I be able to play games like crysis on this tv without any problems? Can the graphics card I chose play Crysis at good settings on this tv? Please shed light on this topic for me (what I can expect playing crysis with this build and what it would take to make it better) because I tried to do some research on it but couldn't really find anything.. Thank you!
A little more information:
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, movies, internet surfing.. Just mostly building it for gaming.. I want to be able to play crysis on it running at good quality.. modern warfare 2.. I also want to be able to play upcoming games..
PARTS NOT REQUIRED: OS, monitor (hopefully)
PREFERRED WEBSITE(S) FOR PARTS: newegg.com is where I buy most of my stuff but I wouldn't mind buying from any respected stores with good discounts now..
PARTS PREFERENCES: I was hoping to be able to put mac on my pc in the near future so I guess parts that are compatible with mac.. I was told the gfx card and mobo that I chose are compatible..
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Very possible later on if needed..
ADDITIONAL COMMENTS: The parts I've listed aren't solid so if there is anything in the build that you feel should be different or there's a better part for just a little more please comment on it too.. I appreciate any help I can get.. Please help me keep this build around 900 if possible.. If not then at least under 1000..
Also, if you think this is just a bad build then please show a better build for around $1000 that would work with everything I want out of it.. gaming wise, mac compatible and with the tv I have..
I thank all of you very much for all you're help and the time you're taking to help me with this! I appreciate it!
THANK YOU!!!
