Tom's Hardware > Forum > Home Theatre > ReplayTV > Weird problem only when recording Smallville
Forum Home Theatre : ReplayTV - Weird problem only when recording Smallville
Archived from groups: alt.video.ptv.replaytv (More info?)
I have tried recording Smallville from two different RTV units over the
last 3 weeks and each time it only records one minute and stops. There
are no programming conflicts and the machines have no problem recording
other shows. Any ideas?
Sponsored Links
On Thu, 20 May 2004 09:57:30 GMT, "BruceR" <brNOSPAM@hawaii.com>
The only ones I've ever had do that, were when there was no video from
the source. You get a "no video detected" error message. You could
check the source (s-video cables come loose more easily).
Mark Lloyd
http://go.to/notstupid
http://notstupid.laughingsquid.com
"It is a curious thing that every creed promises a
paradise which will be absolutely uninhabitable for
anyone of civilized taste." -- Evelyn Waugh
Reply to Anonymous
On one machine it recorded for a few minutes and the other did give me a
No Video message. However, both machines recorded other shows both
before and after. It's not a cable outage because it happens every week
just for Smallville. Maybe it has something to do with Kryptonite ;)
mlloyd@5xxxmail.com5xxx
>> the last 3 weeks and each time it only records one minute and stops.
>> There are no programming conflicts and the machines have no problem
>> recording other shows. Any ideas?
> Mark Lloyd
Reply to Anonymous
On Thu, 20 May 2004 19:47:10 GMT, "BruceR" <brNOSPAM@hawaii.com>
Power outage? If power came back on, you may find the rest of the show
in a different recording.
I have no trouble with that show.
>From:Mark Lloyd
>> Mark Lloyd
Mark Lloyd
Reply to Anonymous
Good thought but no power failure message from units and no indication
from my home automation system which logs power outages. It's a stumper!
>> me a No Video message. However, both machines recorded other shows
>> both before and after. It's not a cable outage
>> From:Mark Lloyd
>>>> stops. There are no programming conflicts and the machines have no
>>>> problem recording other shows. Any ideas?
>>> from the source. You get a "no video detected" error message. You
>>> could check the source (s-video cables come loose more easily).
>>> Mark Lloyd
> Mark Lloyd
Reply to Anonymous
- 0 +
"BruceR" <brNOSPAM@hawaii.com> wrote in news:kM8rc.70$AN1.17
@twister.socal.rr.com:
It is obviously the krptonite causing your RTV to record only black <vbg>
Reply to Steph
There are 687 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
