Solved
Water cooling terminology (tubing, fittings, ect.)
hey guys, im a little confused about the terminology of all the water cooling parts...i know od is outside diameter of tubing and id is inside diameter. what G1/4 though? is that a universal measurement for water cooling parts? because it seems as though they all are G1/4
thanks!
2 answers Last reply Best Answer
More about water cooling terminology tubing fittings
  1. Best answer
    This is covered in the watercooling sticky:
    Quote:
    I.D. - Inside diameter, most commonly referring to the ID of the tubing to be used. 1/2"ID means that wall to wall, the inside of the tubing measures 1/2" (metric is also used and is measured in millimeters or mm)
    O.D.- Outside diameter, similar to the ID, the OD simply is the measurement of the tubing through the cross-section from one side of the outer wall to the other.
    G1/4" - This is the one that confuses the most people. This refers to the threaded fitting standard that is used by almost all waterblocks and radiators. It is the end of the fitting that gets screwed into the block or rad; the other end of this same fitting is measured with the I.D. standard for tubing size.
  2. Best answer selected by plattman02.
Water Cooling Overclocking
