How to check fsb speed of ram
Hello,
how to check the memory size and thw working speed of any type of ram specially DDR II type.
i got a new RAM DDR II 2GB and 800MHz speed but in BIOS it shows only 667MHZ then how to obtain correct info about it???
Please let me know.
1 answer Last reply
More about check speed
  1. Download CPU-Z and it should tell you the current memory speed. Otherwise you'll have to change some settings in the BIOS to increase your memory speed. Just to note though, there's not much difference between 667 MHz and 800 MHz.
Memory RAM DDR
