Final check off on i5 build please help
Hi, I am going to order the parts listed below by the end of tonight
and I would really appreicate it if you guys will help see if my parts are compatible and good, and if there are
any better/cheaper parts out there that would make my computer just as good please feel free to share.
This is my first build, I am super noob at it and please feel free to make any suggestions.
My budget was originally $700 but I got tired of waiting for better deals and want to just build my computer
already. However if you guys know cheaper parts please let me know, I would really want to stay under my
$700 dollar budget. The [v] means I already have it.
CPU: Intel Core i5-750 ($150) [V]
http://www.microcenter.com/single_product_results.phtml?product_id=0317379
MOBO: ASUS P7P55 LX LGA 1156 Intel P55 ATX Intel Motherboard ($119)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131604&cm_re=1156-_-13-131-604-_-Product
GPU: HD 4870 1GB ($150)
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=5034920&csid=ITD&recordsPerPage=10&body=REVIEWS#tabs
Ram: Corsair XMs3 4GB ($94)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260
PSU: Antec Earthwatts EA650 650W ($79)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
Optical Drive: SAMSUNG SH-S223F ($26)
http://www.eworldsale.com/samsung-sh-s223f-bebe-black-22x-double-layer-dvdrw-sata-drive_5706_22429.html
Hard Drive: Seagate Barracuda ES.2 ST3500320NS 500GB ($34) [ did not get this at newegg ] [v]
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148294&cm_re=seagate_500gb-_-22-148-294-_-Product
Case:Cooler Master Storm Scout Case ($49)[v]
http://www.overclockercafe.com/Reviews/cases/CoolerMaster_Scout/index.htm
2 answers Last reply
More about final check build help
  1. Guess I'm too late to post, but you got the right parts for the build. The PSU needs to be at least 500W with 2 6-pin PCI-E connectors. Your PSU exceeds these requirements. Though the PSU and HDD could have been cheaper.
  2. I would get a 5770 over a 4870.
Build Systems Product
