Hi Guys,
I just wanted to iron out a few unsure details before I go ahead and order my kit, if anyone can help with this, please take the time to help me out.
Specs you may need to know of my Pc build are:
Case: NZXT Phantom (full tower)
Chipset: Gigabyte X58-UD3R (Rev 2.0)
Ram: G-skill Ripjaws
CPU: Intel i7 970 socket: 1366
GPU: Radeon Saphirre 6970 Flex Edition.
It's nothing crazy, but basically what i'm ordering is a XSPC Rasa 750 RS360 CPU Water Cooling Kit, but my supplier is changing some things out and replacing for me at extra cost of course, these are the changes i'm changing:
~ Replacing the RS360 Rad with a EX360 Rad (Thanks for the recommendation moto.)
~ Replacing the stock CPU block with a flash new Raystorm intel block.
~ Replacing the standard tubing with PrimoFlex PRO LRT Tubing UV Blue or a Danger Den DreamFlex All-In-One Pack - 3/8" (5/8" OD), Black/UV Blue
~ also throwing in a few killcoils. Possibly two more uv lights.
Now my first question was whether the danger Den tubing will even fit the kits barbs, as it is a different size?
Also, I understand the Ex 360 Rad will fit inside my case up the top but I want to know how much clearance i will have for my ram? or if i will even have any clearance?
I'd like to have the rad inside the case and the fans below the rad so i could have the future possibility of putting some extra fans above the case under the top shell.
I dont think i have any other questions as of now. will ask if I can think of any more.
As always Quick responses are appreciated guys as i am looking at ordering my kit on wednesday next week.
Cheers everyone,
Cheers everyone,
