Solved
Will card and power supply fit my pc
December 4, 2009 11:39:55 PM
I have an HP pavilion 6234 f and am wanting to install a new graphics card and power source. I am thinking about the GTX 260 card and corsair 650 w power supply unit. Does anyone know if these will work with my computer?? It is a core 2 duo 2.70. Just want to play newer games with best res possible
More about : card power supply fit
December 5, 2009 12:20:32 AM
rolli59 said:
If this is it http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01... I do not see a problem
Thanks looks like no problem with power supply. Will it handle that card. It says that card takes up 2 slots. Just want to make sure before I buy. Just got computer and am having trouble running newer games
Looking to set it up so it will allow me to play newer games for awhile
m
l
Best solution
a c 229 U Graphics card
a c 139 ) Power supply
December 5, 2009 12:22:34 AM
The PSU likely won't be a problem. the 260 however is 10.5" long ....take a tape measure and measure the length between ya slots and back of HD cage ....if it's bigger than 10.5, should be doable.
December 5, 2009 12:26:20 AM
Not even sure which slots it is?
m
l
a c 1402 U Graphics card
a c 713 ) Power supply
December 5, 2009 1:26:38 AM
It actually looks like they are dealing with a big card in one of the pictures but as jack said all you have to do is measure.
m
l
