Solved
First Build Problems! Help!!
AHHHH! I just got my system and everything is installed..sort of. For some reason I cannot get a display on my monitor.
I have tried the video card in a different PCI slot and nothing. I also plugged it into my other computer and it worked fine.
All my case fans work, including my heat sink fan, and I can even eject my CD rom drive.
I do not get ANY beep code errors.
All LEDs work. Power button/reset button and everything seems to work fine.
I have tried a different monitor and still nothing. Both monitors I have tried work with another computer.
My ram has LEDs on it which all light up. Even the indicator LEDs on my motherboard light up.
I am left to believe that either my PSU is bad or my MB is bad.
Do you happen to have ANY idea what is going on?
Specs:
i5 750
MSI P55-GD65
Ultra 450W PSU 24A on 12V (I know its low but should be enough for my system.)
HD5770
Seagate 7200.10 750GB
2 answers Last reply Best Answer
More about first build problems help
  1. Best answer
    Seems as if the PCI connector and the graphics card may not be seeding right. Try putting it back in with a bit more force. Use common sense, of course. Turn the computer on its side and really make sure it gets in there and screw it in. If that is a no go, try and wiggle it around a bit after you fire it up (don't electrocute yourself).
  2. I figured it out...and I am an idiot.
    I had my DDR3 in slots 2 and 4 and not 1 and 3.
    I didn't expect the ram layout to be backwards from my previous board.
    So if you are having this problem...try flipping your DDR3 chips.
Homebuilt Monitors Systems
