1st timer multi-purpose i5 750 build - $750 - advice or critique?
Hello. I am about to attempt my first build for a jack of all trades computer. I've already purchased my parts as there were some deals I could not pass up last weekend. I am wondering if there are any issues I might come across with these parts? I am a complete noob so any help or advice putting these particular parts together would be greatly appreciated!
Also, do I need to buy a CPU cooler? I don't plan on overclocking just yet.
Thanks!
APPROXIMATE PURCHASE DATE: last week BUDGET RANGE: $750 After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Movies (1080p capable), Design (Photoshop / Illustrator), audio production (Reason, Ableton), Movies (1080p capable), and some gaming.
PARTS NOT REQUIRED: keyboard, mouse, speakers, OS, DVD-R drive, sound card
OVERCLOCKING: Maybe SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1080
Cooler Master 690 - $39.99 (Newegg w/ rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 - $49.99 (Newegg w/ rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor - $165.36 (Micro Center)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
MSI P55-GD65 LGA 1156 Intel P55 ATX Intel Motherboard - $134.99 (Newegg)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130239
G.SKILL Ripjaws Series 4GB DDR3 SDRAM 1333 (PC3 10666) - $69.99 (Newegg)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231275
Western Digital Caviar Black WD7501AALS 750GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Hard Drive - $59.99 (Newegg)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
HIS H467QS1GH Radeon HD 4670 1GB 128-bit DDR3 - $64.99(Newegg w/ rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161287
SAMSUNG SYNCMASTER 2333SW High Glossy Black 23" 5ms Widescreen LCD Monitor - $137.99 (Dell + Bing CB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001314
*M-AUDIO Audiophile 2496 PCI Interface - *already had
http://www.newegg.com/Product/Product.aspx?Item=N82E16829121120
*LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner with LightScribe - OEM - *already had
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106073
TOTAL $723.29
2 answers Last reply
More about timer multi purpose build advice critique
  1. Nice job of picking things up on sale! That is a fine build. I am sure you will enjoy this computer.
    You should consider adding a CPU cooler because it will be quieter than the stock Intel HSF and will do a much better job of keeping your CPU temperatures low. A Hyper 212 will only add about $30 to your build. But you want to do this while you are assembling the system because you need to be able to get to the back of the motherboard to install the brackets for the HSF. It would be a PITA to try to do this after everything is put together.
    Good luck on your build.
  2. I'm ordering the Hyper 212 Plus right now. Thanks dpaul8! :)
New Build Systems Product
