Solved
I'm building a new water cooled system
May 21, 2012 5:39:41 AM
a c 190 K Overclocking
May 21, 2012 5:50:01 AM
If you haven't already done so, check out the W/c sticky up top, but I have to say damn thats one impressive looking list for a first loop man, way to go :)
No problems there with any of the parts,
the rads a little O/K for a Cpu only loop, are you adding gfx cards in later?
the only change I will insist upon is the coolant, ditch it.
you want plain distilled water with a killcoil or two, if you can manage a UV cathode as well thats great but no worries if not, just drop some PT Nuke in there to kill any growth,
Moto
m
l
May 21, 2012 6:02:59 AM
Moto
Definitely adding cards to the system later, I haven't made up my mind yet on which cards it's either
XFX 7970 CF or 670 SLI I don't know just yet.
m
l
Best solution
May 21, 2012 6:50:54 AM
Either will be shiny, you'll have to scope some reviews for comparisons though and when you do add them, I advise universal blocks, fullcovers are nice but uni's can go onto your next card upgrade,
but you have enough radspace there to handle the addition easily
Moto
May 21, 2012 1:18:04 PM
Best answer selected by earl45.
m
l
May 21, 2012 1:41:53 PM
Thank you for B.a. man, glad to help, and pics in the gallery when you're done?
remember to keep those cables tidy hehhe
Moto
m
l
May 21, 2012 7:13:00 PM
Moto
You got it, as soon as I get the parts installed i'll post pic of the system and the wiring will
be as clean as possible.
m
l
May 21, 2012 7:24:35 PM
Glad to hear it :)
Moto
m
l
May 23, 2012 1:01:58 AM
Quote:
so where are we.?
What do you mean where are we?
m
l
May 23, 2012 1:12:35 AM
Right now it's the cosmo's case, 3770k, sabertooth MB and the two XFX 6950's.
m
l
May 23, 2012 1:17:02 AM
On the water cooling I may change a few parts to nickle plated and instead of the big rad.
go with two 360 rads inside the case at the bottom.
m
l
May 23, 2012 1:21:19 AM
The Nickelplated stuff better not be from EK, thats all I'm sayin :-p
Moto
m
l
May 23, 2012 1:25:29 AM
Moto
I seen some of the nickelplated parts you have and now that I got the new case I'm thinking
about it more and more.
m
l
May 23, 2012 1:28:44 AM
Quote:
now time for those HD 6950's to go.... :p
I was on line checking out the Zotac 670's and XFX 7970's
m
l
May 23, 2012 2:48:48 AM
Can't afford to upgrade anything just yet Mal, although I reckon my 6950's should pull a better resale value than most hehe
Chip will prob be next, depending on how Pd turns out
@Earl, I have nickel yes, but avoid EK nickel like its an underage girl
Moto
m
l
May 23, 2012 3:10:49 AM
Moto
ok will do.
m
l
