Hey, I would like to thank everyone who help me with their much needed advice and wisdom during their busy schedule. Been a great help but now I'm in need of their help again.
So far I took a mixture of computer builds for my $800-$900 from any other builds and I ended up with this:
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC ... - Retail
Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 - Retail
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel Motherboard - Retail
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model F3-16000CL9D-4GBRH - Retail
SAMSUNG CD/DVD Burner Black SATA Model SH-S223C - OEM
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
EVGA 01G-P3-1180-AR GeForce GTX 285 1GB 512-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card - Retail
COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case - Retail
The problem is after I put all the parts together and the wiring. When I push the start button the computer wont turn on at all.
None of the fans work, no lights are turned on but a small light on the corner of the computer that indicated the motherboard has a stable steam of power. No sound also.
I'm not sure if its the Power supply or maybe the case start up wires are messed up.
Any solutions?
Any solutions?
