Need help
i am starting a build and im using the rampage 2 extreme mobo
i have 2 x palit gtx 260 sonic but when i conect both to the mobo the secound GPU card pushes tightly upagainst the top GPU causing it to sit at a slight angle because it needs a couple of mm more
would this damage my gpu cards if i kept it like this
also i am looking for a website where i can find out the exact dimensions of GPU cards not one where it just says "daul slot"
i have seen daul cards on this bord and its designed for tri SLI too so is it that my cards are just too big even thougth this would seem strange
please help
1 answer Last reply
More about need help
  1. ok should be ok then
Graphics Cards GPUs Graphics
