I want to get a new power supply so I can upgrade my graphic card for a better one for gaming but I'm afraid my motherboard can't take it. I contacted Hp but they said the max is 400 watts but I want a 500+ watt but Hp is known for to not know questions so they guess. If you can look at my spec below to see what you guys think I would appricite it very much. I when I do put in a new power supply would i have to reset my Bios?
Thank you
Motherboard specifications table
Part / Feature Specification / Support
Motherboard description Motherboard manufacturer's name: Asus IPIBL-LB
HP/Compaq name: Benicia-GL8E
CPU/Processor Socket: 775
Supports the following processors:
Intel Core 2 Quad (Yorkfield core) Q9xxx
Intel Core 2 Duo (Wolfsdale core) E8xxx
Intel Core 2 Quad (Kentsfield core) up to Q6600
Core 2 Duo E6x00 (Conroe core) up to E6700
Core 2 Duo E4x00 (Conroe core) up to E4400
Front-side bus (FSB) 800/1066/1333 MHz
Chipset Intel G33
BIOS features Keyboard combination to used to enter BIOS: F10
System BIOS core brand: Award
Form factor micro-ATX: 9.6 in X 9.6 in
Memory Dual channel memory architecture
Four 240-pin DDR2 DIMM sockets
Supported DIMM types:
PC2-5300 (667 MHz)
PC2-6400 (800 MHz)
Non-ECC memory only, unbuffered
Supports 2GB DDR2 DIMMs
Supports up to 8 GB on 64 bit PCs
Supports up to 4 GB* on 32 bit PCs
NOTE: *Actual available memory may be less
Expansion slots One PCI
One PCI Express x16 graphics (for graphics cards)
Two PCI Express x1 (for cards such as network, sound, tv-tuner)
Video graphics Integrated graphics using Intel GMA 3100
Also supports PCI Express x16 graphics cards
NOTE: Either integrated graphics or the PCI Express x16 slot are usable at one time; they are not usable concurrently.
Serial ATA Six SATA connectors:
Supports 1 SATA-150 or SATA-300 disk drive on each SATA connector
Speed up to 1.5Gb/sec or 3.0Gb/sec, complying with SATA 1.0 and SATA 2.0 specifications
NOTE: The faster rate of 3.0Gb/sec requires that both the hard drive and the motherboard support it. If one or the other does not support 3.0 Gb/sec, the PC negotiates down to the slower 1.5 Gb/sec.
RAID Onboard RAID controller: ICH9R
Selected Benicia models ship RAID-ready (For Spring 08, only selected CTO models will ship RAID-ready)
RAID modes supported*:
RAID 0
RAID 1
NOTE: RAID 5 requires three HDDs and RAID 10 requires four HDDs. While this motherboard can support RAID 10, only RAID 0 and RAID 1 modes are supported on computer models using this motherboard.
Onboard audio Audio CODEC: ALC888S 7.1 channel high-definition audio
Onboard LAN 1 Realtek 8111C 10/100/1000 Mb/s (Gigabit Ethernet) Integrated LAN
NOTE: Gigabit Ethernet is backwards compatible with 10/100 Mb/s network hardware.
Onboard USB USB 2.0
Twelve ports total
Four connectors on back panel
Six headers (four 1x4 and two 2x5 USB headers) support eight additional USB ports/devices
NOTE: Some USB ports may not be available externally for customer use. For more information, see model specifications.
Onboard 1394 Type: IEEE 1394a 400Mb/s
Agere LFW3227 controller chip
Two ports total
One port on back panel
One header on motherboard supporting one additional port/device
Back panel I/0 One PS/2 mouse port (green)
One PS/2 keyboard port (purple)
One coaxial SPDIF out
One coaxial SPDIF in
One VGA port
Four USB 2.0
One 6-pin IEEE 1394a
One RJ-45 networking port
Six Stereo-mini audio jacks for:
Line-in (light blue)
Microphone-in (pink)
Line-out (lime)
Center/Subwoofer-out (yellow-orange)
Side speaker-out (gray)
Rear speaker-out (black)
Internal connectors One 24-pin ATX power connector
One 4-pin ATX power connector
Six SATA connectors
One floppy drive connector
Two 12v fan connectors for CPU fan and PC fan
One 9-pin header for power button, reset button, power LED, and HDD LED
Three USB 2.0 headers supporting 6 USB ports or devices
One IEEE 1394a header
One SPDIF audio output header
One 4-pin audio line-input connector (interrupts line input on back panel, Vista capable, requires matching front audio jack module)
One 9-pin audio header for headphone-out and microphone-in (yellow, Vista capable, requires matching front audio jack module)
One Intel high-definition Audio/Modem Link (2x8 HDMI connector)
One jumper for resetting BIOS settings
One jumper to disable BIOS password checking
Thank you
Chipset Intel G33
PC2-5300 (667 MHz)
PC2-6400 (800 MHz)
RAID 0
RAID 1
Onboard USB USB 2.0
Twelve ports total
Two ports total
One VGA port
Four USB 2.0
Line-out (lime)
Six SATA connectors
